The annual sky-matrix for the sun disk can be generated using (e.g., from here):
gendaymtx -m 6 -5 0.533 -of assets/NYC.wea > skyVectors/NYCd6.smx
However, if I only want to generate the sky-vector for a certain point in time, what should I use?
I tried:
gensky 3 20 10:30EDT -m 75 -o 73.96 -a 40.78 | genskyvec -m 6 -5 0.533 > NYC_CIE_sun.vec
but got an error:
Unexpected command-line argument: 0.533
Can I simply do
gensky 3 20 10:30EDT -m 75 -o 73.96 -a 40.78 | genskyvec -m 6 -d > NYC_CIE_sun.vec
? In this case, will the absence of the sun disk size '-0.533' information post any problem?
