I am running set wwr measure along with DOE prototype building (Secondary School) in PAT and OS but its giving me error when I apply set WWR measure.Below is the error that I am getting.
Optional not initialized
C:/Users/rwadhwa/AppData/Local/Temp/osmodel-1625060736-1/resources/measures/Set Window to Wall Ratio by Facade/measure.rb:220:in get'
block in run'
C:/Users/rwadhwa/AppData/Local/Temp/osmodel-1625060736-1/resources/measures/Set Window to Wall Ratio by Facade/measure.rb:208:in each'
run'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:515:in `apply_measure'
The strange part is When I change the Buildign type to primary school or other the measure will run without any error.
