Hi - following the walkout basement example for KIVA provided with EnergyPlus I am getting the following error when I remove vertical and horizontal insulation from the Foundation:Kiva object.
Program Version,EnergyPlus, Version 9.4.0-998c4b761e, YMD=2021.06.23 22:13,
** Severe ** Kiva: A cell has been assigned to multiple surfaces.
** Fatal ** Kiva: Errors discovered, program terminates.
I can circumvent the issue by either assigning each surface with it's own Foundation:KIVA object or by using 1mm of insulation as shown below.
Foundation:Kiva,
KIVA_Zone_0, !- Name
, !- Initial Indoor Air Temperature {C}
Basement Insulation, !- Interior Horizontal Insulation Material Name
, !- Interior Horizontal Insulation Depth {m}
0.001, !- Interior Horizontal Insulation Width {m}
, !- Interior Vertical Insulation Material Name
, !- Interior Vertical Insulation Depth {m}
, !- Exterior Horizontal Insulation Material Name
, !- Exterior Horizontal Insulation Depth {m}
, !- Exterior Horizontal Insulation Width {m}
Basement Insulation, !- Exterior Vertical Insulation Material Name
0.001, !- Exterior Vertical Insulation Depth {m}
0.001, !- Wall Height Above Grade {m}
0.001; !- Wall Depth Below Slab {m}
Now I am wondering what KIVA does when I assign each surface its own "Foundation:Kiva" object. Is that still a valid setup? And what is the best way to troubleshoot the above error. Is there a way to export the FE slices/profiles and take a look at them?
