Hi there,
I started with the room models in Buildings recently. I figuered out a lot of the structure of the model, but I'm not able to connect the model Buildings.ThermalZones.Detailed.MixedAir with a second room model MixedAir, like in Buildings.ThermalZones.Detailed.FLEXLAB.Rooms.Examples.X3BWithRadiantFloor.
My approach till now: I opened the example Buildings.ThermalZones.Detailed.Examples.MixedAirFreeResponse and duplicated the Mixed Air model so that I'm having two room models in Buildings.ThermalZones.Detailed.Examples.MixedAirFreeResponse right now. I concted the 2. room with the obligatory parameters weaBus and qGain, I adjusted the romms to the meassurements of my building and exchanged the conecting wall between the rooms with an indoor wall. Till now simulation is working fine. Now I enabled the ports conBou in room1 and conSur in room2 and shifted the connecting wall parameter string to SurBou in room2 and to datConBou in room1, wich seemed to be locical for me. But this is causing an Error
Does anybody have experience in connecting mutiple rooms amongst each other in Buildings or any other Lib?
