My path for the osm is set correctly but when I am running the simulation i am getting this error.
Found error in state 'initialization' with message ["Failed to load OSM file C:/Users/rwadhwa/OneDrive /Documents/PAT/2_BR/temp_data/analysis_31929370-1acd-4b9a-8c73-5b09a1ccdbbd/seeds/2-BR_EnergyModel1.osm::/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/model.rb:67:in load_osm'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_initialization.rb:142:inblock in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/registry.rb:67:in register'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_initialization.rb:142:inperform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'\n:/openstudio_cli.rb:973:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1757:in <main>'\neval:149:ineval'\neval:149:in require_embedded_absolute'\neval:123:inblock in require'\neval:117:in each'\neval:117:inrequire'\neval:3:in `<main>'"]} "
Path has the right osm file but still unable to load what could be the issue?
