I want to run an energyplus simulation for a building with slab from command windows. Since the building has a slab, I cannot use typical syntax in command windows (This way).
I found this post that running energyplus with RunEplus.bat as a potential solution. I got these errors when I use .bat in command windows:
I can run EnergyPlus with EPlaunch. The OS is windows. I tried with a different version of energyplus but this does not work. My energyplus model is Residential Prototype Building Models from PNNL.
