Hello,
I am trying to model an "Autosize" GSHP model for a group of residential building which are in schematic stage of design. I tried to follow some of the example files and other online resources to create the set up. The heating loads and temperatures are working fine but in the cooling mode the demand is meet for few days and rest of the time the outlet temp from the WSHP steadily goes up from the expected 18degC to 30 degC, Refer attached file. Is there any parameter which could affect the cooling capacity/demands directly under GHX objects for an "Autosize" setup? C:\fakepath\2021-06-12_19h57_14.png
Thank you,
