Energyplus FMU issues
Hi everyone,
I am trying to run a FMU from E+. I got this problem in the log file and I do not have a clue what it is happening. I am running this in a container using Docker (EnergyPlus 9.3, .IDF Version 9.3) and PyFMI.
FMIL: module = FMI2XML, log level = 3: fmi2_xml_get_default_experiment_start: returning default value, since no attribute was defined in modelDescription
The model is correctly initialized
lab = load_fmu("Lab_IRH.fmu",log_level=4)
days=60
final_time = days2460*60
start_time = 0
lab.setup_experiment(stop_time=final_time)
But when I try with both of the below setups
Turns out this one give me only zeros at the output of the FMU
stepsize=int(10*60)
i=0
while i<final_time:< p="">
status=lab.do_step(current_t=i,step_size=stepsize,new_step=True)
print(lab.get("TRooMea"))
i=i+stepsize
And this one got stuck infinitely bringing the error above mentioned
test=np.ones(96)*1000
u_traj = np.vstack(test).transpose()
inputs=['Q']
input_object = (inputs, u_traj)
opts=lab.simulate_options()
opts["ncp"] = 600
lab.simulate(final_time=final_time, options=opts)
The socket file is correctly generated and there is not information in the .err generated file. It must be probably something in the modeDescription.xml file in the FMU, but I am not sure. Do you know what can be causing the problem?
Hi everyone,
days=60
load_fmu("Lab_IRH.fmu",log_level=4) days=60 final_time = days2460*60
days*24*60*60 start_time = 0
0 lab.setup_experiment(stop_time=final_time)
stepsize=int(10*60)
i=0
stepsize=int(10*60)
i=0
while i<final_time:
 i=i+stepsize
inputs=['Q']
np.vstack(test).transpose() inputs=['Q'] input_object = (inputs, u_traj)
u_traj) opts=lab.simulate_options() opts["ncp"] = 600
options=opts)
The socket file is correctly generated and there is not information in the .err generated file. It must be probably something in the modeDescription.xml file in the FMU, but I am not sure. Do you know what can be causing the problem? problem?
