I'm working on a project for school using OpenStudio and am receiving several errors stating that the model failed to converge for several of the thermal zones. I have read through the existing questions of other users having a similar issue, but can't seem to find detailed information on what causes this issue. I'm assuming that if I increase the maximum number of warmup days or the tolerance values that I will be able to solve some of the convergence issues, however I'm not sure what values are considered acceptable? I added the "Add Output Diagnostics" reporting measure to my model and used the "reportdetailedwarmupconvergence" input value, but it didn't seem to add any further information to the eplusout.err file. Any help regarding this issue would be much appreciated. Thank you
