Hi I am using openstudio for energy modeling and run a measure called VRF with DOAS system, I want to duct the VRF to VAV box I also tried to create a new loop using packaged rooftop HP with VAV template and create a separate VRF system to model the same system
how can I add vav box to the VRF with DOAS system measure or how can I duct individual VRF controller to packaged rooftop HP with VAV template? What is the difference between those two model ? Thank you
