hello!
I follow the example file "HVACTemplate-5ZoneFanCoil-DOAS.idf", use the fancoil system in my model which has 5 thermal zone, and cooling end uses is electricity, haeting end uses is natual gas.
Now,how can I output each zone end uses data or zone heating/cooling rate(energy)? because I major in architecture, not understand the concepts about "cooling/heating coil,baseboard,fan coil,tower...."
Thank you in advance.
