Hi all,
I am new to EnergyPlus and trying to simulate a radiant floor case. I am getting the error like "Error detected in Object=OUTPUT:VARIABLE" most of the time. The output variable shows blank and there will be no options from the dropdown to select. The same file will simulate without severe errors and shows options under output variables to select sometimes. I couldnot figure where the problem is. If anyone encountered such issues, please guide me to solve this.
Thanks, Prom
