I've been trying to run some idf files through command line using energyplus.exe feature (see here), but I got fetal errors. The same idf file successfully runs through EP-Launch.
Upon checking the forum I realized that energyplus.exe in command line would not run basement.exe and slab.exe preprocessors.
Is there any option to run these preprocessors through command line? I am expecting to use this in both Windows and Linux so RunEPlus.bat might not be an option.
