How to calculate total space heating/air conditioning in EP?
Hi everyone. I am using EnergyPlus to calculate actual space conditioning load for the entire building (facility). The IDF file I am using is one of the prototypes from here (https://www.energycodes.gov/development/residential/iecc_models). I know we can add new outputs in "Output:Meter" for IDF file in IDF Editor, but the available meter options do not include total space heating energy or total AC energy.
For example, based on mtd file, the energy use for cooling should include supply fans, pumps, and cooling coil, but the option "Cooling:Electricity" only considers cooling coil. Other options such as "Fans:Electricity" includes fans for both heating and cooling, which is impossible to separate heating fans from cooling fans.
Is there any option we can use to output total energy use separately for space heating and air conditioning? Thank you.
