Hi everyone, I have been trying to use measure tags for different window configurations but haven't had much luck seeing their respective impact on the simulated building. See below for the described measure tags.
Changing any of these measure tags has had no effect on total building outputs for heating and cooling, regardless of pane number or fenestration low emissivity coating. I feel as if I am missing something obvious here. How can I go about running a simulation that recognises these tags and adjusts the window to reflect these values? Any help would be truly appreciated.
