Why Surface Window BSDF Beam Direction Number was 0?
I used LBNL window to generate a BSDF idf and import the BSDF idf to EnergyPlus.In order to output the hourly BSDF patch number,I set up the output variable "BSDF Beam Direction Number" in EnergyPlus.But output Surface Window BSDF Beam Direction Number was 0 at every hours,Which is why?I have uploaded the idf file and weather file.
I used LBNL window to generate a BSDF idf and import the BSDF idf to EnergyPlus.In order to output the hourly BSDF patch incident direction number,I set up the output variable "BSDF Beam Direction Number" in EnergyPlus.But output Surface Window BSDF Beam Direction Number was 0 at every hours,Which is why?I have uploaded the idf file and weather file.
I used LBNL window to generate a BSDF idf and import the BSDF idf to EnergyPlus.In order to output the hourly incident direction number,I set up the output variable "BSDF Beam Direction Number" in EnergyPlus.But output Surface Window BSDF Beam Direction Number was 0 at every hours,Which is why?I have uploaded the idf file and weather file.
Hi,everyone
I used LBNL window to generate a BSDF idf and import the BSDF idf to EnergyPlus.In order to output the hourly incident direction number,I set up the output variable "BSDF Beam Direction Number" in EnergyPlus.But output Surface Window BSDF Beam Direction Number was 0 at every hours,Which is why?I have uploaded why? below is the idf file link for IDF and weather file.file: https://drive.google.com/drive/folders/1Osoy8KMgMQbcgl7SU8Ulr-0cUOQ95_0d?usp=sharing
Thank you!
Hi,everyone
I used LBNL window to generate a BSDF idf and import the BSDF idf to EnergyPlus.In order to output the hourly incident direction number,I set up the output variable "BSDF Beam Direction Number" in EnergyPlus.But output Surface Window BSDF Beam Direction Number was 0 at every hours,Which is why? why?
below is the link for IDF and weather file: https://drive.google.com/drive/folders/1Osoy8KMgMQbcgl7SU8Ulr-0cUOQ95_0d?usp=sharing
Thank you!
Hi,everyone
below Below is the link for IDF and weather file: file:
Thank you!
Hi,everyone
I used LBNL window to generate a BSDF idf and import the BSDF idf to EnergyPlus.In order to output the hourly incident direction number,I set up the output variable "BSDF Beam Direction Number" in EnergyPlus.But output Surface Window BSDF Beam Direction Number was 0 at every all hours,Which is why?
Thank you!
Hi,everyone
I used LBNL window to generate a BSDF idf and import the BSDF idf to EnergyPlus.In order to output the hourly incident direction number,I set up the output variable "BSDF Beam Direction Number" in EnergyPlus.But output Surface Window BSDF Beam Direction Number was 0 at all hours,Which is why?
Thank you!
Hi,everyone
Thank you!
Why Surface Window is the surface window BSDF Beam Direction Number was 0?beam direction number zero output from energyplus?
Hi,everyone
Thank you!
