when i use material properties :phase change hysteresis what does high/low temperature differences of melting /solidification curve refer to ?? i have read the input output guide but i am still confused
if i have this partial enthalpy from rubitherm for example what would be the numbers i should enter as input
or if there is any solution to get numbers for material property:phase change from this chart as it needs increasing values like ordinary enthalpy curves not partial enthalpy
thanks in advance ..
