Hello team,
I have modeled my building in Openstudio and would like to assign cooling/heating setpoint temperatures for the different thermal zones. I have defined different AHUs loops and FCUs equipment for the different thermal zones. Let us say I want to set the temperature for cooling in summer to 20 C and for heating in winter to 27 C, so these would be the best case scenarios and the system will run when the temperature deviates from these values.
I have seen that there is cooling/heating thermostat schedules in the Thermal zones tabs. Should I put the 20 C as a schedule temperature in the schedules tab and assign it to the cooling thermostat ? And similarly for heating ?
Thanks.
