Do all ResStock houses have adiabatic ground contact surfaces?
Hi,
Hopefully @EricWilson or @DavidGoldwasser can help me out.
I am using E+ v9.2, OS v2.9.0, and ResStock v2.2.4.
I added measure "Set Exterior Walls and Floors to Adiabatic" to my PAT Workflow, only changing "ground_floors" to adiabatic. The other surfaces (ext_roofs, ext_floors, north_walls, south_walls, east_walls, west_walls) were all unaltered by the measure.
The measure should only change the ground exposed floor surface to adiabatic.
only ground floor adiabatic
However, when looking at the log file, I noticed that the total number of adiabatic surfaces before and after the measure runs is the same (14).
same number of adiabatic surfaces
I sampled 10 buildings (datapoints), and they each had this feature in their log file.
This leads me to ask: are all the buildings in ResStock v2.2.4 assigned an adiabatic ground contact surface to begin with?
If so, that would explain why running this measure with ground_floors set to adiabatic doesn't seem to change the model.
Hi,
