Can I change the design day to 1% annual cumulative frequency dry-bulb and wet-bulb temperatures for cooling conditions? When I import a .ddy file the default cooling design day conditions are set to .4%. Is there a way to change this? or does the temperature, humidity, wind solar, etc. data for the 1% design condition have to be entered manually in a custom design day?
