Setting annual ground temp in PAT project
Hi,
I am using OpenStudio v2.9.0, EnergyPlus v9.2, and ResStock v2.2.4.
I would like to override the default E+ ground temp of 18 deg C and set the ground temp equal to the indoor setpoint of 70 deg F.
Is there a OpenStudio or EnergyPlus measure I can add to my PAT workflow to do this? I am not able to edit the IDF file directly, since it is automatically generated through OS-PAT.
