Hi,
I am trying to manually edit a TMY3 epw file to set solar radiation and wind speed to 0 for each timestep throughout the year.
I tried using Elements, but I can only edit one cell at a time.
I also tried using Excel, but there are no column headers when I open the file using comma separated values, so I don't know which variable corresponds to which column of data.
I could not use the WeatherConverter Weather.exe application in EnergyPlus folder because my computer threw an error.
Is there a way to convert epw to csv without using the WeatherConverter? Is there a way to use Elements to easily set the entire annual timeseries for a variable to 0?
