I am modeling a warehouse that is a single space but needs to be broken into multiple thermal zones. I have created the space and zones and have downloaded the Air Wall Zone Mixing measure from the BCL. When I go to apply the measure from the apply measure now window, the modeler description and input fields are empty. Is this an issue with the new version of OpenStudio? I am using OpenStudio Application version 1.1.0 and openstudio SDK version 3.1.0. The measure says its compatible with OS versions 2.8 and later.
