Is there a script available from the command line which can take an IDF created by EPMacro (or by hand, Python, etc.) and sort it into the "normal" order as produced by the IDF Editor when choosing the "sorted" order?
| 1 | initial version |
| 2 | No.2 Revision |
Is there a script available from the command line which can take an IDF created by EPMacro (or by hand, Python, etc.) and sort it into the "normal" order as produced by the IDF Editor when choosing the "sorted" order?order when saving the file?
| 3 | retagged |
Is there a script available from the command line which can take an IDF created by EPMacro (or by hand, Python, etc.) and sort it into the "normal" order as produced by the IDF Editor when choosing the "sorted" order when saving the file?
| 4 | No.4 Revision |
| 5 | retagged |
| 6 | retagged |
