Hello everybody, I currently have an error on a very simple model that I am modelling on OpenStudio 3.1.0, E+9.4. The model is a simple box with 2 windows per wall (it helps me get acquainted with OpenStudio). I do not know how else to upload the file, so you can follow this link here. After the simulation is done (with some warnings) I get the following:
Warn: Annual Overview section failed and was skipped because: Optional not initialized. Detail on error follows.
Warn: AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/measure.rb:286:in `eval
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:540:in `block in output_data_end_use_table'
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:530:in `each'
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:530:in `output_data_end_use_table'
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:258:in `annual_overview_section'
(eval):1:in `block in run'
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/measure.rb:286:in `eval'
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/measure.rb:286:in `block in run'
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/measure.rb:282:in `each'
C:/Users/lucas/AppData/Local/Temp/osmodel-1616494749-2/resources/measures/OpenStudioResults/measure.rb:282:in `run'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:519:in `apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in `each_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:in `perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:in `step'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:234:in `run'
:/openstudio_cli.rb:971:in `execute'
:/openstudio_cli.rb:761:in `execute'
:/openstudio_cli.rb:1755:in `<main>'
eval:175:in `eval'
eval:175:in `require_embedded_absolute'
eval:160:in `block in require_embedded'
eval:154:in `each'
eval:154:in `require_embedded'
eval:113:in `require'
eval:3:in `<main>'
I have a few warnings I still have not figured how to solve, but I think they are not the reason why OpenStudio is not outputting the Annual Overview. I checked that all thermal zones are assigned (it's only one really), so that should not be a problem. Does anyone know what to do to solve this issue? Thank you very much in advance!
Luca.
