ResStock Turn HVAC Off in Apply Upgrade Error
Hi,
I am using ResStock v2.2.4, OpenStudio v2.9.0, and EnergyPlus v9.2.
My housing_characteristics tsv files are edited to have the following distributions: 100% CR09 in Location Region.tsv, 100% Asheville Regional Airport in Location.tsv, 100% Propane in Heating Fuel.tsv and 100% SEER 15 Central AC in HVAC System Cooling.tsv.
This means I am fixing the baseline HVAC equipment and minimizing geospatial extent of the sample.
I am trying to use PAT to turn off HVAC equipment, keeping all the other building characteristics in the sample the same.
I have done this by specifying in the Apply Upgrade Measure Option 1 field;
HVAC System Heating Propane|None
and similarly in the Apply Upgrade Measure Option 2 field:
HVAC System Cooling|None
Both of these parameter|option pairs I sourced from options_lookup.tsv.
When I ran my simulation, all of my columns in results.csv in localResults were blank, and I could not find an enduse_timeseries.csv file in any of my data_point.zip folders.
Any idea why this is happening?
Hi,
My housing_characteristics tsv files are edited to have the following distributions: 100% CR09 in Location Region.tsv, 100% Asheville Regional Airport in Location.tsv, 100% distributions:100% Propane in Heating Fuel.tsv and 100% SEER 15 Central AC in HVAC System Cooling.tsv.
This means I am fixing the baseline HVAC equipment and minimizing geospatial extent of the sample.equipment.
