ZoneHVAC:LowTemperatureRadiant:ConstantFlow
Hello I'm working with ZoneHVAC: LowTemperatureRadiant: ConstantFlow, I have doubts about the meaning of the Zone Radiant HVAC Heating Rate output, if it really symbolizes the heat supplied to the environment, because the delta T of the inlet and outlet water changes, but the rate variation is small. A larger T delta should result in a higher rate. Any suggestion?
