Why kiva results do not make sense?
Hi
I used different models for slab (F Factor, Kiva, Ground Domain) But I found the result for Kiva totally different than other models. In the kiva Model, I have more heat loss in Summer than Winter!!! I checked the example file for this method (Kiva), I faced the same issue and the same pattern for the result?
Would you please help me to understand the reason?
Regards, Roya
Hi
Please find the google drive link that includes the graph and idf file.
https://drive.google.com/drive/folders/1CIGiP3T6yWN3BARnY-hMXC9VFcrQgMlg?usp=sharing
Regards, Roya
Hi
Regards, Roya
