Hello, I am a student working in OS (3.1.0) modelling a residential building. To have an balanced air flow in every zone we are adding the "add zone mixing object". I was wondering if someone could explain more in detail what this object does. I know that you enter a zone exhaust (for example kitchen) and a source zone (for example living) and a airflow in (cfm). This means that air only goes from one zone to the other and not reverse? The airflow is constant and needs to be in cfm? (So I have to calculate from m^3/hour to cfm) I can ad as many zone mixing objects to a zone as I want? The most information I have found on this question.
Does someone have any tips or advice of other objects I could use to simulate the residential building?
