Hello I am a thesis student working in OS 3.1.0 and we have by comparing the fluid heat exchanger with an other student something very strange detected.
Our fluid heat exchanger is different from theirs but we use the same object, how is this possible? the other student is working in OS 3.0.0 the other student (3.0.0)
our object heat exchanger
As you can see they have the important fields: 1) loop demand side inlet/outlet node 2) heat exchanger setpoint node name
Does someone know how this is possible?
