Hi,
I am looking for a variable to quantify total heating or cooling delivered to a single-family detached residential building. These types of buildings typically only have one or two conditioned spaces (living zone/bedroom). The end goal is to use a heat balance model to estimate a building’s thermal mass and bulk conductivity.
I am using a single stage ASHP to deliver heating and cooling. Ideally there is one variable that represents HVAC load delivered to all conditioned zones, after it has been heated/cooled by fans, heat transfer with refrigerant loop, etc. My educated guess is that the variable is one of the following:
- Unitary System Total Cooling Rate
- Unitary System Sensible Cooling Rate
- Unitary System Total Heating Rate
- Unitary System Sensible Heating Rate
I think “Unitary System” variable is appropriate because it combines heating/cooling from all the components on the supply side of the air loop (fans, coils etc), before the conditioned air is delivered to the zone.
Is Unitary System Total Heating/Cooling Rate the best variable for what I have described? Should I consider the Sensible Rate instead, since that is what actually changes the zone temp? Am I leaving out an energy flux ([W]) if I use Unitary System Total Heating/Cooling Rate?
