I have been trying to bring in hourly changes in simulation conditions that take values from a .csv file and convert them to the values take by the EMS sensor. This I am trying to implement on 2 aspects: 1. The construction (in order to change the aspects of SHGC and Visible Transmittance values of a Simple Glazing unit), for which I'm creating 7 states which are defined in the code and trying to choose the appropriate construction based on the corresponding value in .csv file. 2. The LPD of artificial lighting by choosing the appropriate value for the hour from the .csv file.
The end-result that I'm trying to acheve is similar to the question asked in https://unmethours.com/question/47169/how-to-add-variable-envelope-properties-in-energyplus-through-ems/ , but I faced difficulty in implementing it which is why I have posted as a separate question. Kindly help me out. The input .csv files that I want to use are attached here
I'm attaching the code that I had tried, but it doesn't seem to be working. Since I'm a beginner in Measure Writing, I have tried to combine snippets from the following codes:
- M13Example13SurfaceConstructionActuatorForThermochromaticWindow: https://github.com/NREL/OpenStudio-EMS-Measures/blob/master/Measures/m_13_example_13_surface_construction_actuator_for_thermochromatic_window/measure.rb
- Set Lighting Loads by LPD: https://bcl.nrel.gov/node/84704
- Replace Exterior Window Constructions with a Different Construction from the Model: https://bcl.nrel.gov/node/84690
- Add Interval Schedule From File: https://bcl.nrel.gov/node/84422
My Code:
# load dependencies
require 'csv'
# start the measure
class DynamicWindowGlazing < OpenStudio::Measure::ModelMeasure
# display name
def name
return "Dynamic Window Glazing"
end
# description
def description
return "This measure adds an EMS object and a schedule object from a file of interval data"
end
# modeler description
def modeler_description
return "This measure simulates a dynamic glazing by adding an EnergyPlus object, Energy Management System and a ScheduleInterval object from a user-specified .csv file. The measure supports hourly and 15 min interval data for leap and non-leap years. The .csv file must contain only schedule values in the first column with 8760, 8784, 35040, or 35136 rows specified. See the example .csv files in the tests directory of this measure."
end
# define the arguments that the user will input
def arguments(model)
args = OpenStudio::Measure::OSArgumentVector.new
# make an argument for removing existing
remove_existing_schedule_intervals = OpenStudio::Ruleset::OSArgument::makeBoolArgument('remove_existing_schedule_intervals', true)
remove_existing_schedule_intervals.setDisplayName('Remove existing ScheduleInterval objects?')
remove_existing_schedule_intervals.setDefaultValue(false)
args << remove_existing_schedule_intervals
# 1) Choice List of a FixedWindow subsurface to apply a thermochromic window construction to
fixed_window_subsurface_handles = OpenStudio::StringVector.new
fixed_window_subsurface_display_names = OpenStudio::StringVector.new
subsurface_array = []
# put all model subsurfaces and names into arrays
model.getSurfaces.each do |surface|
surface.subSurfaces.each do |sub_surface|
subsurface_array << sub_surface
end
end
subsurface_array.each do |subsurface|
if subsurface.subSurfaceType == "FixedWindow"
fixed_window_subsurface_handles << subsurface.handle.to_s
fixed_window_subsurface_display_names << subsurface.name.to_s
end
end
# make a choice argument for a subsurface of type FixedWindow
fixed_window_subsurface = OpenStudio::Ruleset::OSArgument.makeChoiceArgument('fixed_window_subsurface', fixed_window_subsurface_handles, fixed_window_subsurface_display_names, true)
fixed_window_subsurface.setDisplayName('Choose a Fixed Window Subsurface to Replace with an EMS generated Electrochromic window construction.')
fixed_window_subsurface.setDefaultValue('Perimeter_ZN_1_wall_south_Window_1')
args << fixed_window_subsurface
# make an argument for schedule name for Construction Schedule
schedule_name_1 = OpenStudio::Ruleset::OSArgument::makeStringArgument('Construction Schedule', true)
schedule_name_1.setDisplayName('Construction Schedule:')
schedule_name_1.setDefaultValue('Construction Schedule From File')
args << schedule_name_1
# make an argument for file path for Construction values
file_path_1 = OpenStudio::Ruleset::OSArgument.makeStringArgument('file_path_1', true)
file_path_1.setDisplayName('Enter the path to the file that contains schedule values (follow template in test folder of this measure):')
file_path_1.setDescription("Example: 'C:\\Projects\\values.csv'")
args << file_path_1
# make an argument for schedule name for Artificial Lighting Schedule Schedule
schedule_name_2 = OpenStudio::Ruleset::OSArgument::makeStringArgument('Artificial Lighting Schedule', true)
schedule_name_2.setDisplayName('Artificial Lighting Schedule:')
schedule_name_2.setDefaultValue('Artificial Lighting Schedule From File')
args << schedule_name_2
# make an argument for file path for Artificial Lighting values
file_path_2 = OpenStudio::Ruleset::OSArgument.makeStringArgument('file_path_2', true)
file_path_2.setDisplayName('Enter the path to the file that contains schedule values (follow template in test folder of this measure):')
file_path_2.setDescription("Example: 'C:\\Projects\\values.csv'")
args << file_path_2
## requirements for artificial lights
# make a choice argument for model objects
space_type_handles = OpenStudio::StringVector.new
space_type_display_names = OpenStudio::StringVector.new
# putting model object and names into hash
space_type_args = model.getSpaceTypes
space_type_args_hash = {}
space_type_args.each do |space_type_arg|
space_type_args_hash[space_type_arg.name.to_s] = space_type_arg
end
# looping through sorted hash of model objects
space_type_args_hash.sort.map do |key, value|
# only include if space type is used in the model
if !value.spaces.empty?
space_type_handles << value.handle.to_s
space_type_display_names << key
end
end
# add building to string vector with space type
building = model.getBuilding
space_type_handles << building.handle.to_s
space_type_display_names << '*Entire Building*'
# make a choice argument for space type or entire building
space_type = OpenStudio::Measure::OSArgument.makeChoiceArgument('space_type', space_type_handles, space_type_display_names, true)
space_type.setDisplayName('Apply the Measure to a Specific Space Type or to the Entire Model')
space_type.setDefaultValue('*Entire Building*') # if no space type is chosen this will run on the entire building
args << space_type
# add in argument to add lights to all spaces that are included in building floor area even if original space didn't have lights
add_instance_all_spaces = OpenStudio::Measure::OSArgument.makeBoolArgument('add_instance_all_spaces', true)
add_instance_all_spaces.setDisplayName('Add lights to all spaces included in floor area, including spaces that did not originally include lights')
add_instance_all_spaces.setDefaultValue(false)
args << add_instance_all_spaces
return args
end
# define what happens when the measure is run
def run(model, runner, user_arguments)
super(model, runner, user_arguments)
construction_array = []
ems_window_construction_array = []
# use the built-in error checking
if not runner.validateUserArguments(arguments(model), user_arguments)
return false
end
# assign the user inputs to variables for schedules
remove_existing_schedule_intervals = runner.getBoolArgumentValue('remove_existing_schedule_intervals', user_arguments)
schedule_name_1 = runner.getStringArgumentValue('schedule_name_1', user_arguments)
file_path_1 = runner.getStringArgumentValue('file_path_1', user_arguments)
schedule_name_2 = runner.getStringArgumentValue('schedule_name_2', user_arguments)
file_path_2 = runner.getStringArgumentValue('file_path_2', user_arguments)
# assign the user inputs to variables for artificial lights
object = runner.getOptionalWorkspaceObjectChoiceValue('space_type', user_arguments, model)
add_instance_all_spaces = runner.getBoolArgumentValue('add_instance_all_spaces', user_arguments)
# check the space_type for reasonableness and see if measure should run on space type or on the entire building
apply_to_building = false
space_type = nil
if object.empty?
handle = runner.getStringArgumentValue('space_type', user_arguments)
if handle.empty?
runner.registerError('No SpaceType was chosen.')
else
runner.registerError("The selected space type with handle '#{handle}' was not found in the model. It may have been removed by another measure.")
end
return false
else
if !object.get.to_SpaceType.empty?
space_type = object.get.to_SpaceType.get
elsif !object.get.to_Building.empty?
apply_to_building = true
# space_type = model.getSpaceTypes
else
runner.registerError('Script Error - argument not showing up as space type or building.')
return false
end
end
# get existing schedules
schedule_intervals = model.getScheduleIntervals
# report initial condition
runner.registerInitialCondition("number of ScheduleInterval objects = #{schedule_intervals.size}")
# remove existing schedules
schedule_intervals.each(&:remove) if remove_existing_schedule_intervals
# check schedule name for reasonableness
if schedule_name == ''
runner.registerError('Schedule name is blank. Input a schedule name.')
return false
end
# check file path for reasonableness
if file_path.empty?
runner.registerError('Empty file path was entered.')
return false
end
# strip out the potential leading and trailing quotes
file_path.gsub!('"', '')
# check if file exists
if !File.exist? file_path
runner.registerError("The file at path #{file_path} doesn't exist.")
return false
end
# read in csv values
csv_values = CSV.read(file_path,{headers: false, converters: :float})
num_rows = csv_values.length
# create values for the timeseries
schedule_values = OpenStudio::Vector.new(num_rows, 0.0)
csv_values.each_with_index do |csv_value,i|
schedule_values[i] = csv_value[0]
end
# infer interval
interval = []
if (num_rows == 8760) || (num_rows == 8784) #h ourly data
interval = OpenStudio::Time.new(0, 1, 0)
elsif (num_rows == 35_040) || (num_rows == 35_136) # 15 min interval data
interval = OpenStudio::Time.new(0, 0, 15)
else
runner.registerError('This measure does not support non-hourly or non-15 min interval data. Cast your values as 15-min or hourly interval data. See the values template.')
return false
end
##beginning of window construction change
shgc=[0.1,0.2,0.3,0.4,0.5,0.6,0.7]
tvis=[0.1,0.2,0.3,0.4,0.5,0.6,0.7]
(0..7).each do |j|
# create construction and material and link them together
construction = OpenStudio::Model::Construction.new(model)
material = OpenStudio::Model::SimpleGlazing.new(model)
# add material to constructions
construction.insertLayer(0,material)
# set material properties
material.setUFactor(2.56)
material.setSolarHeatGainCoefficient(shgc[j])
material.setVisibleTransmittance(tvis[j])
construction = [SimpleGlazing]
construction_array << construction
ems_window_construction = OpenStudio::Model::Construction.new(const)
ems_window_construction.setName("Construction #{[j]}")
runner.registerInfo("Created a new Construction named #{ems_window_construction.name} representing an electrochromatic window construction.")
ems_window_construction_array << ems_window_construction
end
# check the user argument of the fixed window subsurface for reasonableness
if fixed_window_subsurface.empty?
handle = runner.getStringArgumentValue('fixed_window_subsurface', user_arguments)
if handle.empty?
runner.registerError('No fixed window subsurface was chosen.')
else
runner.registerError("The selected fixed window subsurface with handle '#{handle}' was not found in the model. It may have been removed by another measure.")
end
return false
else
if !fixed_window_subsurface.get.to_SubSurface.empty?
fixed_window_subsurface = fixed_window_subsurface.get.to_SubSurface.get
else
runner.registerError('Script Error - argument not showing up as construction.')
return false
end
end
# creating an output variable for Schedule Value for Window Construction
output_var_1 = "Schedule Value for Window Construction"
output_var_construction = OpenStudio::Model::OutputVariable.new(output_var_1, model)
# create a sensor to sense the Schedule Value for Window Tvis
construction_sensor = OpenStudio::Model::EnergyManagementSystemSensor.new(model, output_var_construction)
construction_sensor_name = "Construction Sensor"
construction_sensor.setName(construction_sensor_name)
# creating an output variable for Schedule Value for Artificial Lighting
output_var_2 = "Schedule Value for Artificial Lighting"
output_var_art_light = OpenStudio::Model::OutputVariable.new(output_var_2, model)
# create a sensor to sense the Schedule Value for Artificial Lighting
art_light_sensor = OpenStudio::Model::EnergyManagementSystemSensor.new(model, output_var_art_light)
art_light_sensor_name = "Artificial Lighting Sensor"
art_light_sensor.setName(art_light_sensor_name)
# Create a new EMS Actuator Object representing the construction state of the EMS generated electrochromatic window
ems_win_construct_actuator = OpenStudio::Model::EnergyManagementSystemActuator.new(fixed_window_subsurface, "Surface", "Construction State")
ems_win_construct_actuator.setName("Window_Construction_Set")
runner.registerInfo("An EMS Actuator object named '#{ems_win_construct_actuator.name}' representing construction state of the EMS generated electrochromatic window was added to the model.")
# Create 7 EnergyManagementSystem:ConstructionIndexVariable objects for each unique electrochromatic construction
ems_window_construction_array.each do |ems_window_construction|
ems_constr_index_var = OpenStudio::Model::EnergyManagementSystemConstructionIndexVariable.new(model, ems_window_construction )
ems_constr_index_var.setName("#{ems_window_construction.name}")
runner.registerInfo("An EMS SystemConstructionIndexVariable object named '#{ems_constr_index_var.name}' representing the the EMS construction state of the electrochromatic window was added to the model.")
end
# Create new EnergyManagementSystem:Program object for assigning different window constructions by dynamically evaluating the exterior surface temp of the fixed window subsurface
ems_apply_electrochromatic_constructions_prgm = OpenStudio::Model::EnergyManagementSystemProgram.new(model)
ems_apply_electrochromatic_constructions_prgm.setName("#{fixed_window_subsurface.name}_Control")
ems_apply_electrochromatic_constructions_prgm.addLine("IF #{construction_sensor.name} == 1")
ems_apply_electrochromatic_constructions_prgm.addLine("SET #{ems_win_construct_actuator.name} = 'Construction 1'")
ems_apply_electrochromatic_constructions_prgm.addLine("ELSEIF #{construction_sensor.name} == 2")
ems_apply_electrochromatic_constructions_prgm.addLine("SET #{ems_win_construct_actuator.name} = 'Construction 2'")
ems_apply_electrochromatic_constructions_prgm.addLine("ELSEIF #{construction_sensor.name} == 3")
ems_apply_electrochromatic_constructions_prgm.addLine("SET #{ems_win_construct_actuator.name} = 'Construction 3'")
ems_apply_electrochromatic_constructions_prgm.addLine("ELSEIF #{construction_sensor.name} == 4")
ems_apply_electrochromatic_constructions_prgm.addLine("SET #{ems_win_construct_actuator.name} = 'Construction 4'")
ems_apply_electrochromatic_constructions_prgm.addLine("ELSEIF #{construction_sensor.name} == 5")
ems_apply_electrochromatic_constructions_prgm.addLine("SET #{ems_win_construct_actuator.name} = 'Construction 5'")
ems_apply_electrochromatic_constructions_prgm.addLine("ELSEIF #{construction_sensor.name} == 6")
ems_apply_electrochromatic_constructions_prgm.addLine("SET #{ems_win_construct_actuator.name} = 'Construction 6'")
ems_apply_electrochromatic_constructions_prgm.addLine("ELSEIF #{construction_sensor.name} == 7")
ems_apply_electrochromatic_constructions_prgm.addLine("SET #{ems_win_construct_actuator.name} = 'Construction 7'")
ems_apply_electrochromatic_constructions_prgm.addLine("ENDIF")
runner.registerInfo("An EMS Program Object named '#{ems_apply_electrochromatic_constructions_prgm.name}' for dynamically assigning different window constructions based on the exterior surface temp was added to the model.")
# loop through construction sets used in the model
default_construction_sets = model.getDefaultConstructionSets
default_construction_sets.each do |default_construction_set|
if default_construction_set.directUseCount > 0
default_sub_surface_const_set = default_construction_set.defaultExteriorSubSurfaceConstructions
if !default_sub_surface_const_set.empty?
starting_construction = default_sub_surface_const_set.get.fixedWindowConstruction
# creating new default construction set
new_default_construction_set = default_construction_set.clone(model)
new_default_construction_set = new_default_construction_set.to_DefaultConstructionSet.get
# create new sub_surface set
new_default_sub_surface_const_set = default_sub_surface_const_set.get.clone(model)
new_default_sub_surface_const_set = new_default_sub_surface_const_set.to_DefaultSubSurfaceConstructions.get
# assign selected construction sub_surface set
new_default_sub_surface_const_set.setFixedWindowConstruction(construction)
new_default_sub_surface_const_set.setOperableWindowConstruction(construction)
# link new subset to new set
new_default_construction_set.setDefaultExteriorSubSurfaceConstructions(new_default_sub_surface_const_set)
end
end
end
# Create a new EnergyManagementSystem:ProgramCallingManager object configured to call the EMS programs
ems_prgm_calling_mngr = OpenStudio::Model::EnergyManagementSystemProgramCallingManager.new(model)
ems_prgm_calling_mngr.setName("My Electrochromic window emulator")
ems_prgm_calling_mngr.setCallingPoint("BeginTimestepBeforePredictor")
ems_prgm_calling_mngr.addProgram(ems_apply_electrochromatic_constructions_prgm)
runner.registerInfo("EMS Program Calling Manager object named '#{ems_prgm_calling_mngr.name}' added to call EMS program for dynamically applying a electrochromatic window.")
lighting_power_reduction_percent = runner.getDoubleArgumentValue('lighting_power_reduction_percent', user_arguments)
# create unique object for OutputEnergyManagementSystems and configure to allow EMS reporting
outputEMS = model.getOutputEnergyManagementSystem
outputEMS.setInternalVariableAvailabilityDictionaryReporting("internal_variable_availability_dictionary_reporting")
outputEMS.setEMSRuntimeLanguageDebugOutputLevel("ems_runtime_language_debug_output_level")
outputEMS.setActuatorAvailabilityDictionaryReporting("actuator_availability_dictionary_reporting")
runner.registerInfo("EMS OutputEnergyManagementSystem object configured per user arguments.")
runner.registerFinalCondition("Measure finished with #{model.getEnergyManagementSystemSensors.count} EMS sensors, #{model.getEnergyManagementSystemActuators.count} EMS Actuators, #{model.getEnergyManagementSystemPrograms.count} EMS Programs, #{model.getEnergyManagementSystemSubroutines.count} EMS Subroutines, #{model.getEnergyManagementSystemProgramCallingManagers.count} EMS Program Calling Manager objects")
##end of window construction change
##preliminary settings for artificial lighting setup
# make a hash of old defs and new lights and luminaire defs
cloned_lights_defs = {}
cloned_luminaire_defs = {}
# loop through space types
space_types.each do |space_type|
next if space_type.spaces.size <= 0
space_type_lights = space_type.lights
space_type_lights.each do |space_type_light|
# clone def if it has not already been cloned
exist_def = space_type_light.lightsDefinition
if cloned_lights_defs.any? { |k, v| k.to_s == exist_def.name.to_s }
new_def = cloned_lights_defs[exist_def.name.to_s]
else
# clone rename and add to hash
new_def = exist_def.clone(model)
new_def_name = new_def.setName("#{exist_def.name} - #{lighting_power_reduction_percent} percent reduction")
cloned_lights_defs[exist_def.name.to_s] = new_def
new_def = new_def.to_LightsDefinition.get
end
end
end
# link instance with clone and rename
updated_instance = space_type_light.setLightsDefinition(new_def.to_LightsDefinition.get)
updated_instance_name = space_type_light.setName("#{space_type_light.name} #{lighting_power_reduction_percent} percent reduction")
space_type_luminaires = space_type.luminaires
space_type_luminaires.each do |space_type_luminaire|
exist_def = space_type_luminaire.luminaireDefinition
if cloned_luminaire_defs.any? { |k, v| k.to_s == exist_def.name }
new_def = cloned_luminaire_defs[exist_def.name]
else
new_def_name = new_def.setName("#{new_def.name} - #{lighting_power_reduction_percent} percent reduction")
cloned_luminaire_defs[exist_def.name] = new_def
end
end
# getting spaces in the model
spaces = model.getSpaces
# get space types in model
if apply_to_building
else
if !space_type.spaces.empty?
spaces = space_type.spaces # only run on a single space type
end
end
spaces.each do |space|
space_lights = space.lights
space_lights.each do |space_light|
exist_def = space_light.lightsDefinition
else
end
end
updated_instance = space_light.setLightsDefinition(new_def.to_LightsDefinition.get)
updated_instance_name = space_light.setName("#{space_light.name} #{lighting_power_reduction_percent} percent reduction")
end
space_luminaires = space.luminaires
space_luminaires.each do |space_luminaire|
exist_def = space_luminaire.luminaireDefinition
else
end
updated_instance = space_light.setLightsDefinition(new_def)
updated_instance_name = space_light.setName("#{space_light.name} - #{lighting_power_reduction_percent} percent reduction")
end
##beginning of artificial lighting change
art_light_states=[5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80]
(0..16).each do |j|
# create a new LightsDefinition and new Lights object to use with setLightingPowerPerFloorArea
template_light_def = OpenStudio::Model::LightsDefinition.new(model)
ems_art_light = OpenStudio::Model::LightsDefinition.new(light)
ems_art_light.setName("Light #{art_light_states[j]}")
runner.registerInfo("Created a new Artificial Light named #{ems_art_light.name} representing an electrochromatic window construction.")
ems_art_light_array << ems_art_light
end
# Create a new EMS Actuator Object representing the artificial lighting state of the EMS generated artificial light
ems_art_light_actuator = OpenStudio::Model::EnergyManagementSystemActuator.new(lightsDefinition, "Light", "Lighting State")
ems_art_light_actuator.setName("Artificial_Lighting_Set")
runner.registerInfo("An EMS Actuator object named '#{ems_art_light_actuator.name}' representing lighting state of the EMS generated electrochromatic window was added to the model.")
ems_art_light_array.each do |ems_art_light|
ems_art_light_index_var = OpenStudio::Model::EnergyManagementSystemLightIndexVariable.new(model, ems_art_light )
ems_art_light_index_var.setName("#{ems_art_light.name}")
runner.registerInfo("An EMS SystemLightIndexVariable object named '#{ems_art_light_index_var.name}' representing the the EMS construction state of the artificial light was added to the model.")
end
ems_apply_art_light_prgm = OpenStudio::Model::EnergyManagementSystemProgram.new(model)
ems_apply_art_light_prgm.setName("#{fixed_window_subsurface.name}_Control")
ems_apply_art_light_prgm.addLine("IF #{art_light_sensor.name} == 10")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 10")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 15")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 15")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 20")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 20")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 25")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 25")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 30")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 30")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 35")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 35")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 40")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 40")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 45")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 45")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 50")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 50")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 55")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 55")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 60")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 60")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 65")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 65")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 70")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 70")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 75")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 75")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 80")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 80")
ems_apply_art_light_prgm.addLine("ELSEIF #{art_light_sensor.name} == 85")
ems_apply_art_light_prgm.addLine("SET #{ems_art_light_actuator.name} = 85")
ems_apply_art_light_prgm.addLine("ENDIF")
runner.registerInfo("An EMS Program Object named '#{ems_apply_art_light_prgm.name}' for dynamically assigning different artificial lighting based on the values in the uploaded file was added to the model.")
ems_prgm_calling_mngr_2 = OpenStudio::Model::EnergyManagementSystemProgramCallingManager.new(model)
ems_prgm_calling_mngr_2.setName("My Artificial Lighting emulator")
ems_prgm_calling_mngr_2.setCallingPoint("BeginTimestepBeforePredictor")
ems_prgm_calling_mngr_2.addProgram(ems_apply_art_light_prgm)
runner.registerInfo("EMS Program Calling Manager object named '#{ems_prgm_calling_mngr_2.name}' added to call EMS program for dynamically applying a electrochromatic window.")
# make a schedule
startDate = OpenStudio::Date.new(OpenStudio::MonthOfYear.new(1), 1)
timeseries = OpenStudio::TimeSeries.new(startDate, interval, schedule_values)
schedule = OpenStudio::Model::ScheduleInterval::fromTimeSeries(timeseries, model)
if schedule.empty?
runner.registerError("Unable to make schedule from file at '#{file_path}'")
return false
end
schedule = schedule.get
schedule.setName(schedule_name)
# reporting final condition of model
runner.registerFinalCondition("Added schedule #{schedule_name} to the model.")
return true
end
end
# this allows the measure to be use by the application
DynamicWindowGlazing.new.registerWithApplication
Error Message
Standard Output:
[openstudio.measure.OSRunner] No value found for argument 'schedule_name_1'.
[12:02:02.564909 ERROR] No value found for argument 'schedule_name_1'.
[12:02:02.565728 ERROR] C:\OS\src\measure\OSRunner.cpp@753 : No value found for argument 'schedule_name_1'.
C:/Users/nycta/OpenStudio/Measures/dynamic_window_glazing/measure.rb:137:in getStringArgumentValue'
run'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:515:in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in
block in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'
apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:in
step'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:234:in run'
:/openstudio_cli.rb:963:in
execute'
:/openstudio_cli.rb:753:in execute'
:/openstudio_cli.rb:1747:in
eval:175:in eval'
eval:175:in
require_embedded_absolute'
eval:160:in block in require_embedded'
eval:154:in
each'
eval:154:in require_embedded'
eval:113:in
require'
eval:3:in '
[12:02:02.569900 ERROR] :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb failed with C:\OS\src\measure\OSRunner.cpp@753 : No value found for argument 'schedule_name_1'., C:/Users/nycta/OpenStudio/Measures/dynamic_window_glazing/measure.rb:137:in
C:/Users/nycta/OpenStudio/Measures/dynamic_window_glazing/measure.rb:137:in run'
apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in block in apply_measures'
each_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:in step'
run'
:/openstudio_cli.rb:963:in execute'
execute'
:/openstudio_cli.rb:1747:in '
eval:175:in
eval'
eval:175:in require_embedded_absolute'
eval:160:in
eval:154:in each'
eval:154:in
require_embedded'
eval:113:in require'
eval:3:in
' in :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:543:in rescue in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:503:in
apply_measure'
each_index'
perform'
run'
execute'
eval:175:in
eval'
eval:160:in
eval:154:in each'
eval:154:in
require_embedded'
eval:3:in
[12:02:02.570632 ERROR] Found error in state 'os_measures' with message [":/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb failed with C:\OS\src\measure\OSRunner.cpp@753 : No value found for argument 'schedule_name_1'., C:/Users/nycta/OpenStudio/Measures/dynamic_window_glazing/measure.rb:137:in getStringArgumentValue'\nC:/Users/nycta/OpenStudio/Measures/dynamic_window_glazing/measure.rb:137:in
run'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:515:in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in
block in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in
apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:in
step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:963:in
execute'\n:/openstudio_cli.rb:753:in execute'\n:/openstudio_cli.rb:1747:in
'\neval:175:in eval'\neval:175:in
require_embedded_absolute'\neval:160:in block in require_embedded'\neval:154:in
each'\neval:154:in require_embedded'\neval:113:in
require'\neval:3:in ' in :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:543:in
rescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:503:in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in
require'\neval:3:in '::/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:652:in
rescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:310:in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in
require'\neval:3:in `'"]}
Standard Error:
run.log:
run'
apply_measures'
step'
execute'
eval:175:in eval'
eval:175:in
eval:154:in
each'
eval:113:in
require'
eval:3:in '
apply_measure'
each_index'
perform'
run'
execute'
eval:175:in
eval'
eval:160:in
eval:154:in each'
eval:154:in
require_embedded'
eval:3:in
apply_measure'
each_index'
perform'
run'
execute'
eval:175:in
eval'
eval:160:in
eval:154:in each'
eval:154:in
require_embedded'
eval:3:in
