Hi there,
I am wondering if it is possible o use EMS to alter the shade construction?
I can define a window with shade construction in the window control object, but it appears that I am unable to modify this construction by EMS once it is set.
I was thinking about instead of window shade control, I just assign the construction with shade to the window surface and then use EMS to dynamically change window construction. However, this failed also because "Window must not directly reference a Construction with a shading device. Use WindowShadingControl to specify a shading device for a window."
I am quite stuck here because I cannot think other alternatives.
Does anyone know how to get around this? If not, any anyone know what are the equivalent solutions?
