So I've been changing my insulation values by increasing its thickness as well as lowering its thermal conductivity in the 'Material' section under the Surface Construction Elements list, but no matter what I change the values to, my output numbers are always the same. Am I not accounting for something? Or is it a case where the insulation values aren't actually affecting the results to a noticeable extent? The program runs without any errors, and I have tried changing the values by a magnitude of 100 but to no avail, any help is appreciated!
(The EnergyPlus version I'm using is v9.4.0)
