when i simulate 4 different spaces with same thermal zone and insert internal gain of people by number of people 30 would energyplus calculate that 30 person in each space or will divide the number for the 4 spaces so i have to make it 30*4?
another question is when two spaces with the same thermal zone i found that the wall between them isn't located in building surface detailed can i add it manually in the idf editor (as i need to simulate PCM in this wall ) or i will get error?
