Hi, I am trying to conduct an optimization with a sample DOE large office reference building using jEPlus EA. I developed my parameters of interest using jEPlus and have obtained results with no problem. But when trying to conduct the optimization simulations with jEPlus EA I get below errors. The model is developed for a small test I did by changing cooling set point temperatures for small sample size. O can see the EnergyPlus output results but somehow I cannot see the graphs (especially Pareto Front that I need).
Does anyone have any suggestions?
Error:
"Simulation results contain the following errors:
C-0_0_3 - case is missing - no results available
C-0_0_2 - case is missing - no results available
C-0_0_1 - case is missing - no results available
C-0_0_0 - case is missing - no results available
C-0_0_4 - case is missing - no results available"
