I am using Python plugin to overwrite some variables from EnergyPlus (v9.4), such as: zoneSAT, zoneSAF, AHU-SAT, AHU-SAF, OAT. I tried to send back the original values, instead of modified variable values. I also tried to give back the modified variable values.
But both simulations crashed with errors: zone surface temperature out of bounds.
The eplusout.err file also shows warnings related with: PsyWFnTdpPb, PsyPsatFnTemp.
What are the possible solutions?
The errors:
** Severe ** Temperature (high) out of bounds [500.38] for zone="ROOM B2", for surface="WS_1F_WALL"
** ~~~ ** Environment=RUN PERIOD 2, at Simulation time=04/24 16:37 - 16:38
** Fatal ** Program terminates due to preceding condition.
...Summary of Errors that led to program termination:
..... Reference severe error count=68353084
..... Last severe error=Temperature (high) out of bounds [500.38] for zone="ROOM B2", for surface="WS_1F_WALL"
Other warnings:
************* ** Warning ** Entered Humidity Ratio invalid (PsyWFnTdpPb)
************* ** ~~~ ** This error occurred 1372823 total times;
************* ** ~~~ ** during Warmup 0 times;
************* ** ~~~ ** during Sizing 0 times.
************* ** ~~~ ** Max=48288876.468566 [] Min=16.917983 []
************* ** Warning ** Temperature out of range [-100. to 200.] (PsyPsatFnTemp)
************* ** ~~~ ** This error occurred 73070170 total times;
************* ** ~~~ ** Max=479.781769 C Min=-39027.041016 C
************* ** Warning ** CalcDoe2DXCoil: Coil:Cooling:DX:TwoStageWithHumidityControlMode="ROOFTOP COOLING COIL" - Air volume flow rate per watt of rated total cooling capacity is out of range error continues...
************* ** ~~~ ** This error occurred 883147104 total times;
************* ** ~~~ ** Max=9.233481E-006 Min=2.711692E-008
COIL" - Full load outlet temperature indicates a possibility of frost/freeze error continues. Outlet air temperature
statistics follow:
************* ** ~~~ ** This error occurred 161418 total times;
************* ** ~~~ ** Max=-6.936612 Min=-21439.224791
