Hi i need to add solar thermal collector for DHW
Hi i need to add this solar thermal collector for DHW in the building in order to reduce the amount of fuel of the boiler needed for Domestic hot water heating
This is the solar collector i want to add image description
In my building i have added before a FCU unit in which the boiler is used for heating the space and the domestic sanitary water
The question is do i need to connect this solar collector type to the boiler from the FCU (HVAC Plant template) or or not? image description
Thanks
Thanks Thanks
Thanks
Thanks
