I am a student working on my thesis. I am modelling a building in OS 2.7.0
I have done some research and found the following (https://unmethours.com/question/15684/design-specification-zonehvac-sizing-object-name-in-zonehvacidealloadairsystem/), they say that design specification outdoor air object is optional and you can leave it blank.
But I get for my rooms where there is supply air with a diffuser the following error. * Severe * Controller:MechanicalVentilation="CONTROLLER MECHANICAL VENTILATION 1", Design Specification Outdoor Air Object Name blank * ~~~ * For Zone="THERMAL ZONE 10". * ~~~ * This field either needs to be filled in in this object or Sizing:Zone object. * ~~~ * For this run, default values for these fields will be used. I also get following warning * Warning * GetOAControllerInputs: Controller:MechanicalVentilation="CONTROLLER MECHANICAL VENTILATION 1 * ~~~ * Cannot locate a matching DesignSpecification:OutdoorAir object for Zone="THERMAL ZONE 10". * ~~~ * Using default OA of 0.00944 m3/s-person and 0.0 m3/s-m2.
those problems air solved if i place an design specification outdoor air object but I don't want that.
Someone with a solution or knows what causes the problem? you can find the files in this link (https://we.tl/t-txH3z8iOGc) error file 11-11 and openstudio, error file 11-10 doesn't give that problem but then I need to implement a design specification outdoor air object in space types
