I'm trying to apply the "Create DOE Prototype Building" measure to generate the prototypical lab building (with that building type added manually to the list of building types in the measure, which is expected to work), using the version of the Create DOE Prototype Building measure downloaded today from the BCL, and version 1.0.0 of the OpenStudio Application. The Ruby gemfile in the OpenStudio Application folder specifies version 0.2.11 of openstudio-standards, which should be compatible with the lab building option for this measure.
I’m getting the error message in the image attached (about energy_recovery being an unknown keyword) C:\fakepath\Measure_Error.PNG when I try to apply this measure (with a vintage of 2010, which the option should be compatible with). I noticed that the energy_recovery argument is no longer in the model_add_doas method in the master branch of openstudio-standards on GitHub, so maybe that is part of the problem. Does anyone have advice on troubleshooting this? Thanks!
