Hello there,
Regarding the Dymola Behavior Modeling, I have added all the libraries including "Modelica Standard Library 3.2.3", "Modelica Service Library 3.2.3" and "Building Library 7.0.0". I ran the simulation from the example provided in the building library (Chiller plant). I got the following error.
Function OpenModelica. Scripting.uriToFilename is not known in(function ModelicaServices.ExternalReferences.loadResource)
I also checked the environment variable and it looks three paths related to the 3 libraries are available. I would appreciate it if you could answer my question!
