I wrote a custom OpenStudio measure, i.e. it is not from BCL. It works just fine in the OpenStudio 2.9.1 Application when I call it from the Components & Measures -> Apply Measure Now menu. However, when I go to the Measures tab of the OpenStudio 2.9.1 Application (third to last on the left edge, near the bottom, just above the Run tab and the Results tab) and then select that measure from the Library and then drag it to the OpenStudio Measures slots (above the EnergyPlus Measures slots and the Reporting Measures slots), it lands there ok, but when I click on it, the arguments do not show up? Why don't they show, and how can I make them show? Thanks.
