The case study I am trying to simulate is basically 4 individual rooms/apartments that are connected by a corridor. Sliding windows are opened in each room, and doors of each room are opened. The corridor does not have windows, so air runs through the room windows - exits through room doors - flows through the corridor and then enters through another room door and exit through a window. I want to use natural ventilation to predict the mean indoor air temperature of each room/apartment under those conditions (then validate by comparing results with data that was already collected in situ). The rooms/apartments are located in the 20th floor of an apartment building of total 32 floors. I am using coupled simulation using SketchUp OS plugin and OS app. I already tried using this Natural ventilation measure https://bcl.nrel.gov/node/82785 - which describes that is not intended to be use for interzone modeling. I used this measure and created a construction material for operable windows - and assigned it to one side of the sliding window of each room and to the doors. Not all windows from the rooms are operable - some are fixed too; and doors are operable. However, I do not know if results are accurate - because the measure does not calculate interzones. With this background information. How would you simulate the natural ventilation between interzones using operable windows/doors? Thank you.
