Hello hello
I need to connect a Solar thermal collector with the storage for DHW,
Question 1) I added the parameters for Solar collector Performance: Flat Plate and for Solar collector: Flat Plate: Water, the thing is in the Flat Plate: Water, what should i add in Inlet Node Name and Outlet Node name (Demand or Supply)?
Question 2) Can anyone tell how can i connect the Solar Thermal collector with a storage for Domestic Hot Water (DHW)?
Thank you very much
Best Regards
