Hi all,
In order to include PCM effect in EnergyPlus and run the simulation, either the technical datasheet or enthalpy-temperature figure is needed to operate the simulation. Are there any sources available that contain this information for different PCM types?. Almost all the companies I contacted did not share their datasheet.
Any recommendation is appreciated.
