I am trying to take an existing hospital building file (idf) from Atlanta, Georgia, and simulating it with a weather file (IWEC) from Johannesburg, SA. Based on my research, Johannesburg and Atlanta should have similar climates. I didn't make any additional changes in the idf file except changing the latitude, longitude, time zone, and elevation to match Johannesburg numbers. I am encountering this severe error in which the chiller is failing. Has anybody dealt with this before? Please help
* Severe * FindRootSimpleController: Controller error for controller = "CAV_2_COOLC_CONTROLLER" * ~~~ * Environment=RUNPERIOD 1, at Simulation time=08/26 01:45 - 02:00 * ~~~ * Controller function is inconsistent with user specified controller action = Reverse action * ~~~ * Actuator will be set to maximum action * ~~~ * Controller control type=Temperature and humidity ratio * ~~~ * Controller temperature setpoint = 7.76E-003 [C] * ~~~ * Controller sensed temperature = 7.81E-003 [C] * ~~~ * Controller humidity ratio setpoint = 7.76E-003 [kgWater/kgDryAir] * ~~~ * Controller sensed humidity ratio = 7.81E-003 [kgWater/kgDryAir] * ~~~ * Controller actuator mass flow rate set to 12.37 [kg/s]
