On https://bigladdersoftware.com/epx/docs/9-4/input-output-reference/group-design-objects.html#field-design-outdoor-air-flow-rate we can read that about the "Design Outdoor Air Flow Rate" field of "Sizing:System" object:
The design outdoor air flow rate in cubic meters per second. Generally this should be the minimum outdoor air flow.
Can someone please confirm that there is no error in the documentation and that "minimum outdoor air flow" is correct?
