Hello, I posted a comment here https://unmethours.com/question/46754/updating-to-the-most-recent-ashrae-2018-library/ since this question was somewhat related to mine but thought starting a new post may help in getting a response.
Does the 90.1-2016 baseline exactly follow the 90.1-2004 baseline? i.e. would following the suggestion from this post https://unmethours.com/question/46754/updating-to-the-most-recent-ashrae-2018-library/ using the "Create Baseline Building" measure provide me with the 90.1-2016 baseline that can be used for LEED v4.1? Various sources refer to the 2016 baseline as "roughly equal" to the 2004 baseline, so wasn't sure if there was other modifications required to the 2004 baseline to get to the 2016 baseline. Thanks!
