Hi.
I went through my first project with OpenStudio and built a very basic building in Bellingham. After finishing my project, my results tab would show a report from OpenStudio and EnergyPlus. However, when I saved my project later that evening there was an error, the weather data was lost, and the application crashed.
Now after re-adding the Bellingham weather data, when I run my program and look at the results tab, only the EnergyPlus report is available. I can no longer see the OpenStudio report.
Does anyone know what happened? How can I fix this so that I can see the OpenStudio report again?
Thank you!
