when i simulate a floor should i make a shading surface group for each space or it is enough to draw a shading surface group for whole geometry at once ? which one is more correct and accurate?
| 1 | initial version |
and when should i draw shadding surface ? after matching geometry surfaces or before ? thanks in advance
| 3 | retagged |
